Have a new aftermarket wheel in your room you want to install, but don't know exactly how? Watch, Read, and Learn.
1. Locate steering wheel.
2. Take your small screwdriver and pop the H emblem off the wheel.
3. Locate the steering wheel nut. 19mm or 13/16".
4. Find the appropriate socket/extention
5. Zip it out with an impact gun if you've got one. The reason I say use this is because you don't have to worry about the wheel moving very much as you rip the nut off, as opposed to useing a hand-powered ratchet.
6. If the nut doesnt come out in the socket, it'll just sit there like yay:
7. Then go ahead and pull the wheel off.
8. Slip on the new hub.
-Next Post-
-Next Post-
