1 - 16 of 16 Posts
DIY Guru
96 Ranger-stock
How to install a Heli-Coil
The subject is a Toyota 2ZZ engine block
The bolt holes were cracked and then were welded making the holes out of line. The heli-coil will make this a simple fix.
The tools needed will be a Drill motor, the proper sized drill bit for the heli-coil kit, the heli-coil tap, install tool, and the heli-coil insert.
The Heli-coil kit being used is a 8 x1.25mm
The drill bit needed is 21/64
Install the drill bit into the drill motor, and drill the hole out.
Blow out the hole with compressed air
Next take the heil-coil tap
DIY Guru
96 Ranger-stock
Tap the hole to its oversize.
*NOTE* Heli-Coil taps are an odd size.
On aluminum use a cutting fluid.
Keep the tap straight and square to the work piece.
Blow the hole out again
Now put the insert on the install tool
Now carefully screw the insert into the threads that were just cut, being careful not to apply too much force and skip a thread.
Make sure to counter sink the top of the heil coil by a thread or two
Once the insert is in properly, snap the bottom tab off and blow it out of the hole.
All done and ready to have the part bolted back!
Love the Civic
Holy out of focus pics batman, but so useful. You should stop smearing the Vaseline on the lens for soft image flare. Or use better lighting, think of it like a porn shoot. Your words with good pics would make a manual out of your stickies.
DIY Guru
96 Ranger-stock
A tap is for making threads in a hole.
A Heli-coil is to replace the threads in a damaged hole.
Each have there place.
DIY Guru
96 Ranger-stock
Well I have gone thu several cameras at the shop, The first was a 4meg. As they were dropped or knocked over They have been replaced.
I also learned about the "Macro" setting. That is why the ones I wrote early on have the worst pics.
'92 CX Twincharged D
A lot the newer smart phones are the best little cameras to have.
My G3 takes great picts, I use it for documenting at the foundry I work at.
ek9 hatch, ej6 coupe
Do u recommend going oversized with a tap/bolt when possible or helicoil? When I bought my spare block the assclown had stripped the timing belt tensioner bolt. Tried longer to no avail so I went larger with the tap. It's all to spec and holds just fine obviously but in your professional opinion what's the better route if welding and tapping isn't available at the time?
Love the Civic
I think it all depends on the metal being inserted, its relative closeness to other things, and the pressure being exerted on the part. Stuff I think about before choosing a method, have used all with success once I learned to take my time. Coiled a spark plug on the side of a road, was dicey to blow out crap with piston and just hope, but the car ran for years after ward. Ah my red dodge neon....highline style. Thing was a piecer.
DIY Guru
96 Ranger-stock
If it works it works, some times the next size bolt will not work, so having the knowledge of a few methods is handy.
These work okay sometimes, but I prefer Time-Serts.... similar idea, they just seem to last the test of time when done correctly.
I can see that if it is a bolt the is being run in and out often. The only time I really go for a time sert is spark plug holes, I just never like a spring coil in that position
I think it all depends on the metal being inserted, its relative closeness to other things, and the pressure being exerted on the part. Stuff I think about before choosing a method, have used all with success once I learned to take my time. Coiled a spark plug on the side of a road, was dicey to blow out crap with piston and just hope.
That ^^^^^ It covers it pretty damn well, all I could say is some other odd repair on the side of the road.
Love the Civic
The heli coil is a harder metal, usually due to aluminium heads and such, it can hold better in pressure situations where changing the bolt size won't work for many reasons, spark plugs, exhaust mani bolts etc. There is no real can and cant situations that don't involve looking at the application in question and measuring the pro and cons on site.
Off the top of my head, you have a weird size bolt, and in a bolt pattern that can be bad looking or time consuming have another wrench on had when servicing.
I wouldn't use a heli coil if the pressure on the bolt was across its head like hanging something from it.
I can agree that there are some times that each method would serve a "better" purpose... Its also very nice that DIY topics like this are posted..... very informative. Love it.
1 - 16 of 16 Posts
