1 - 3 of 3 Posts
H
Is there any ways to do that?
Rather than swapping D16y pistions, can I use any of the dohc parts? Please help
Friend from Thailand welcome!
By your question of "increasing capacity" I assume you mean increasing displacment???
If that is what you mean then you can only alter displacment by either changing the piston size or changing the stroke of the crank.
Both ways would take a lot of effort as well as $$$$
Your best bet is to find a 1.6 core if you're looking for more displacement.
H
i'm looking for more than 1.6L, and yes that's what i meant displacement (i'm not good at technical terms in English). I'm looking for more than that, i'm now swapped to 1.6. So can I use any dohc parts to build it up?
1 - 3 of 3 Posts
