21 - 22 of 22 Posts
I didn’t think y’all would like a new thread so I choose this “latest” idle thread.
My idle surges. It will idle perfect at 550 when I manually close this diaphragm. It doesn’t close all of the way. I see the adjustment screw that I would have to take off the whole tb to get to but it doesn’t need to be backed off because it never bottoms out. I thought about seeing if I could wined the tb spring around one extra time but doubted weather it would go completely around. It’s obvious someone made an attempt at the screws. If I cut the heads off of those screws will that diaphragm slide off or is it threaded also. I was thinking I could remove it and remove material from the side of the diaphragm that makes contact with the tb. lowering its profile resulting in the plunger sitting deeper inside of it.
135709
135710
I took off the IACV and added some forma gasket and that fixed the surging but the idle is high bc of that dashspot diaphragm i manually close it and its idle low it’s great. Instead of f ing up my stuff I’ll see if ace hardware springs I can wrap around it and the plunger arm
21 - 22 of 22 Posts
