1 - 20 of 29 Posts
ef hatch beater
anyone have a diagram of how to do this by any chance?
any input is appreciated however.
to be specific it is an obd1 z6 dizzy, wanting to do this so i can run the msd blaster coil.
88 ED6
External caps still needs the coil to be be wired; all the caps do is allow the main coil negative("spark wire") to be hooked up to the distributor; but do not address the actual +/- coil wires.
The stock ignition has been proven to withstand a nice amount of power. I did the msd cap and blaster coil on a old b18 build and saw very little improvement. Everyone that posted nailed the head on the coffin with how to do it! Best of luck man
Will I have to do the timing again? I will etch the position of my dizzy to the head so I can line it back up. I've done it on b2 and it worked. But since I am changing cap and rotor to msd, will I need to time it again even if I line up my etch marks? All that make sense? Obviously I don't have a timing light and don't have quick access to one. Thanks
an ej8 coupe
if you leave the dizzy bolted to the head you shouldn't need to time it.
94 dx hatch
If the rotor is indexed right you shouldn't have any problems... same with the cap
MSD blaster is a waste unless your pulling well over like 400whp lol.
Had it on my stock Y8 when I first got the car and all it kept doing was burning plugs out.....Changed it all back to stock with NGK and no problems ever since....This was 5 years ago.
OMG TOTALLY COOL TITLE!!!!
88 y49 crx
IIRC they have pushed stock ignition passed 500. ill have to search to refresh my memory
^^^ Your probably right bud!
I was just throwing it out there that more than likely with the OP's question that its more trouble than will actually help him.
Your cutting a factory wire to jimmy rig up an external coil.....OEM= Reliability
Aftermarket = Meh 50/50% Reliability lol.
1 - 20 of 29 Posts
