1 - 15 of 15 Posts
1991 Honda Civic SI
Hey guys I have googled searched and I have d-series searched and there are about 25 million different ways I have seen to clean your gas tank to get it free from rust.
co2..pressure washer + vinegar, Iso Alcohol 91-99%, Clean Gas etc. etc. etc. but what do y'all reccomend?
Also when I got the tank off and got to the fuel pump I noticed the strainer was clogged full of rust etc. so I took it off and set it in a cup of gas hooked it up to the car primed the new fuel filter and it cranked until it ran out of gas ( it's a bitch feeding it out of a mason jar)
Do you think with that being said it will hold enough FP to opporate the car under normal terms or should I go about replacing it? Mightyjoecivic sent me a 92-95 fuel pump which isn't the same but I can modify it to work.. should I go that route? Thanks again guy's rep will be spread!
91 CRX Si
Most yards around here poke holes in the tanks prior to putting them out...sux.
1991 Honda Civic SI
Ours do was about to say the same thing, it's not easy enough to take a 17mm and take the drain off they poke holes in em like swiss cheese so that's not too much of an option =/
Defender of the D
OOHHHH OOOHHH OHHH I'll bring the marshmallows and graham crackers..
Defender of the D
I can't be xpected to bring everything.. but in all seriousness... radiator shops most of the time can pretty much hottank ur gas tank.. that should get all the rust out..
The Great Weldini
91 civic
1991 Honda Civic SI
Lol, I think I am gunna try rinsing it with gas about 10-15 more time's until I get a better color almost clear coming out running 2 tanks of gas in it then change the filter
No Tune No Life!
99 Supercharge Regal
Curious George
'99 LX Civic Sedan
There is many places specialized in gaz and fuel tanks refurbish. It's often cheaper than a brand new, and they offer warranty.
1 - 15 of 15 Posts
