1 - 6 of 6 Posts
I have a 2003 Honda EX 5 D17A2 I am trying to remove the pistons from under the car. I removed the oil pickup strainer. The oil pickup strainer is attached to I believe is the engine girdle? Please correct me here. I need to remove that so I can see easier the bottom of the pistons so I can remove them? Does this make sense? I removed the very long bolts but not sure if this part needs to be removed. It does not budge and I am not sure if this is the correct procedure to remove the piston while the engine block is still in the car.
What are the torque specs for these long bolts and the oil pickup strainer?
Thanks
They only come out the top after you remove the cylinder head.
Discussion Starter · #4 ·
Never mind I got the piston. I need the torque specs for the piston nuts and bolts that hold the bottom of the engine crankshaft. I am not sure what it is called. The oil pickup filter is screwed into it.
1 - 6 of 6 Posts
