1 - 4 of 4 Posts
hi guys, looking to add more camber at the rear to fit my 8 j rota's having not owned a honda before just trying to work out in my head how the arms work to had camber without adding to much toe, to me looking at the hub if i get shorter arms or adjustable arms this will force more toe on the hub, is this correct?
yes. Any change in ride hheight and camber will cause a toe change. You will need an alignment where they can adjust the camber to make your tires fit and then adjust the toe as necessary.
1 - 4 of 4 Posts
