1 - 20 of 23 Posts
ej2
sorry bout tha sleeping lol..
i worded my topic wrong..
It should now be "Should i use seafoam in my gas tank?"
i'm reading alot of old post and people dont like it too much...
91 CRX Si
works pretty good on older cars with high miles. Just will probably need to change your spark plugs afterwards.
\/Your Mom Was Here\/
Vibe GT
Go get some GM top engine cleaner. we use it on our toyota's at the shop here. works great. P/N#88861802. but you dont use it in the tank, you use it through the intake with a small vacuum hose. use about half the bottle
98 honda civic LX
X2
shouldnt need the foam unless you car is running like poopoo. and like beer drinkin said if you DO use it just pull your brake boost line off and suck it up through there.
and yes plug change imo thats what i would do after the foam
ej2
lol..only asking guys.
i just thought since i got the new engine
and i just changed the oil.. i would use lucas and seafoam..
but i see seafoam isn't the answer
99 Civic Ex coupe
half the can in the gas & half in the oil right before an oil change seemed to help my 92 4door a bit ... but highly recommend during oil change asap after running it through the oil...
Well?
lucas top end lube and cleaner. one bottle for a whole tank of gas
91 CRX Si
LOL, bad experience?
No, I just take care of the motor so it is not needed.
I've seen/read about 4-5 hydrolocked motors and 2-3 others where carbon was loosen.....and ended up on the exhaust valve seat requiring the head to be removed.
Poop Sock
wrx & slut rex
how many miles are on your hoopty? if youre seals are kinda old and you have lots of miles it'll just make your seals worse. i put a quarter up my brake booster, 1/8 in my oil, and 1/8 in my gas on a full tank. do that then let it idle till opperating temp and then go drive it hard. mine smoked A FUCKING LLLOOOOOOOOT! ppl were honking at me yelling "YOUR CARS ON FIRE!" then go home and do an oil change.
ej2
Its a like new motor from H motors!
motor has at least 20k on it!WO0t!
New seals..new head gaskets..errrrrrrthing damn near new!
i'm just tryin to take precautions.
BMX bike
mantain it regularly with decent oil, and wind it out every once in a while is what I would suggest.
IMO, seafoam type cleaners = snake oil
1 - 20 of 23 Posts
