1 - 20 of 28 Posts
How much money have you spent on your turbo kit??
I'll start by posting how much I have invested
Turbo $100
Adapter plate $62
STD manifold free
DP and cheapo boost gauge trade, had to pay for shipping $15
BOV $30 shipped
starion intercooler $40 shipped
misc. fitting $20
tuner toys oil feed fitting $22
oil pressure gauge $20
tranny oil cooler line $10
chipped ecu w/ datalogging $70
chip burner $50
WBO2 $300
laptop $100, though I've used it for other stuff, bought it for burning chips. Over paid for it to.
Total $838
still need 450's, intercooler piping, possibly a different intercooler, probably couplers, maybe air filter for turbo, oil return line, HF and IHI turbo gaskets, and ebay cat. So, I'm probably looking at another $300.
You can put together a cheap kit if you get deals or hookup on parts. If not your going to put a little money into a kit. IF you run an FMU and forget it, it's obviously going to be a lot cheaper then doing it right with a chipped ecu and WBO2.
Honda
ive spent alot.... havent calculated it but heres the breakdown of what i have by means of parts
Engine:
- Std. bore Z6 block, honed cylinder walls
-Arias 9:1 compression forged pistons
-Crower steel billet I-beam connecting rods
-Crower rod bolts
-ACl main bearings (if the spec out, oem if they dont)
-ACL rod bearings (if they spec out, oem if they dont)
-Arp head studs
-Oem head gasket (all other gaskets oem also)
-Endyn block posts (not sure if i will use or not, but i do have them)
-3 angle valve job Z6 head
-Supertech valve springs
-Supertech titanium retainers
-Skunk2 camshaft
-Skunk2 intake manifold (y8 )
-GSR 60mm throttle body
-Sage racing 6-bolt adjustable cam gear
Turbo Setup:
-Garrett T3/TO4E 54 trim turbocharge .70 coldside .64 hotside. stage 1 wheel
-CCFAB mini ram tubular turbo manifold
-3" downpipe
-DSM evo 8 blow off valve
-Turbonetics 38mm Wastegate
-Turbo XS Dual-Stage Boost Controller
-Blaast performance oil line kit
-Blaast performance 7-bolt DP flange
-28" x 3" x 6" FMIC w/ 2.5" inlet and outlet
-2.5" black charge piping
-Turbonetics Deltagate wastegate (8psi internal spring)
-Tuner Toys Vacuum manifold
-Vacuum manifold fittings
Fuel:
-Walbro 255lph low pressure fule pump
-Y8 fuel rail
-Y8 fuel pressure regulator
-Lucas 550cc injectors
Electronics:
-P28 ecu
-Hondata s200 with boost
-Resistor box
-Autometer boost guage
-Autometer oil pressure guage
-SVE 3 bar map sensor
Drivetrain:
-Z6 tranny
-OBX Limited Slip Differential
-Act Xtreme Pressure plate
-JKMotorsports Traction Bars
-Act Performance Street Disc
-New misc. bearings in tranny
Suspension:
-Dropzone struts
-Tien s-tech drop springs
-Motor mount inserts (possibility, havent decided yet)
-15" speedy wheels
-Goodyear GT Pro 195/50/15 tires
Honda
DAM son, your balling.
I meant more on like the actual kit, but whatever. How much have you spent??
alot.......dont really know. moneys not an issue at all so i just see something and buy it.
T-25 turbo and 02 housing with all the lines plus intercooler piping and 2g dsm intercooler $40
HF manifold $25
DP and boost gauge $60
BOV free
misc. fitting free
P-28 already have lying around for vtec swap i bought for $160
I just need boost controller which i have but wont go lower than 18 psi, hf mani to turbo adapter plate, oil lines that go off my block for feedline all of this i am looking at spending no more than $45 shipped boost controller, hf mani to turbo adapter plate $20, oil lines off block whole kit for d motor $80 shipped
So i have spent $125 and will spend no more than $250 when i am done just need to make an oil feedline off block to turbo and i knock it down to no more than $200 when i am done.
The reason i got all this stuff is i bought a wrecked 2g 95 tsi awd for $200 and i got all the stuff i needed sold the car for 900 and i used to own a dsm before the honda so i had some free parts lying around.
Discussion Starter · #9 ·
HF manifold $25
BOV free
misc. fitting free
I think you might have the record.
Yeah, parting out turbo car's is great. They have a bunch of random shit that can be used. I parted out a ford probe gt that I got a few usefull parts from. The crossmember is in the way on EF's, but on EG's or EK's I'm pretty sure the stock DP on the ford probe gt will work if you use an IHI turbo, from me trying to mock it up to my EF. It has a flex pipe on it so it'll give a bit.
Like I said, unless you get super duper deals a turbo kit can get a little pricey. More then you think, before you start piecing one togehter.
The H Badge is it!
91 crx
dsm t25 with o2 housing, very mint no shaft play at all - 100 bucks
hf mani - 30
dsm bov - free
450cc injectors - free
adapter - 55
oil lines - 85
fmic - 120
boost gauge - 55
chipped pm6 w/ datalogging - 80
moates burn1 - 50
my charge pipes - 75ish
couplers - 20 bucks
odds and ends - 70
total- 745
i still plan to get a wb, laptop and welder
Lifetime Awesome Member
'89 CRX HF
First setup:
HF manifold - free
adapter plate - free(homemade)
TE04H turbo - $70
CCA fmic - $130
oil lines - $78
chipped ecu - $75
charge pipes/DP - $75
couplers/clamps - $75
DSM 450s - $40
DSM bov - $35
DSM flange - $25
boost gauge - $45
Total - $648
add in the burner, Ostrich, Wideband, and clutch and it goes up about $520
Second setup:
Log manifold - $100
t3 turbo - $100
DP flange and piping - $50
gaskets - $30
obd1 conversion harness - $54
chipped obd1 ecu - $100
charge pipes/couplers/injectors from last setup
Total - $937
New setup has not been totaled yet, and im not sure i want to...
full greddy turbo kit
act clutch+extreme presuure plate
450cc injectors
uberdata tuned ecu
greddy fmic
everything installed $500
where did you get that kit for soooo cheap?
FAMILY MEMBER #316
i hate all of you.
2400 on my turbonetics kit because i am a total retard and didnt know shit about turbos when i bought it.
$12 for new plugs (ngk)
$65 for new wires (ngk)
$65 for a/f and boost gauges
being able to say my car is boosted...priceless
Reactions: Chiovnidca
hf mani - 30
dsm bov - free
adapter - 55
oil lines - 85
fmic - 120
boost gauge - 55
moates burn1 - 50
couplers - 20 bucks
odds and ends - 70
total- 745
you can use my ostrich.
BTW your ZIF socket came in the other day. I need a freaking chip dude lol
1 - 20 of 28 Posts
