1 - 20 of 21 Posts
I Wanted To Put This Thread Together To Get An Idea Of How Much Boost You Guys Are Running And If Your With Stock Sleeves Or Sleeved. So Just Write How Much Boost,sleeved Or Not And Hp If Possible. Lets See Who The Top Dog Is Fellas!!!!!!:tu:
all i was asking was for to tell a little about your guys setup thats all
ok, if you want to know a set-up then here you go:
stock y7 head
y7 block bored .5mm over
9:1 srp pistons
y8 hg
arp head studs
tt rods
ching chong chang 57 trim t3/to4e @ 19 psi (max) fall off to 17 psi (red line)
cast manifold
turbonetics deltagate
2.25 hot pipes to a 30x11x3 fmic to 2.5 cold pipes
greddy type r/s bov
550cc injecotrs
60-65* fuel pressure @ wot and max boost (93 oct)
12.1-12.4 a/f under load (boost)
mustang dyno settings were 2600 lbs car at 10% load
~280 whp on a mustang dyno, got 35 mpg on average.
btw: i did not include timing pulled/total for a reason. i do not want some one to try and follow my build and then blast me when they blow there sh!t up.
edit: i also have pics from when i pulled the head off to sell the bottom end. and it was mint in there. an people say you can't make power with a y7 engine ;).
racist-bigot-sexist-homophob
thanks man,thats a nic setup there. thats what i like to see. now that wasnt so hard was it
yes, since i have posted it many many times on the site. and others have posted theres also. you just have to look for them. aka search. there have been atleast 50 threads dealing with this same subject.
1 - 20 of 21 Posts
