1 - 13 of 13 Posts
Just woundering if anyone knows how much boost a stock dohc zc can handle safely without droppin a piston, blowin the valve train or just basically fryin the engine? Any input would be awsome!
Thanks.
Ranger - work truck
psi is a relative question depending on the cfm output of the turbo you could have a kkk03 turbo at 20 psi put out the same amount of air as a t-70 at 2 psi the real question you should ask is what HORSEPOWER can i run on my stock block before it grenades......then find a turbo that isnt stressing itself to be at that hp level and build from there
1 - 13 of 13 Posts
