1 - 17 of 17 Posts
C
Ok I have to project to built and I need to know aproximatively the hp of eatch.
1 project
Block d15b(7 i think)
Head d16z6 with light port and polish
Itb
D16z6 header
Second projet
Block d16y7
Head d16z6 with very lightport and polish
Crower stage 1 cam
Itb
Bisimoto header
Civic turbo Hx/Ex
1 project
Itb
D16z6 header
Second projet
Block d16y7
Crower stage 1 cam
Itb
Bisimoto header
Next to nothing... why don't you just do it and report back to us on what you gained?
9
I would guess betwine 130 and 160 hp on both builds. might be less than that I dont know. it depends on a lot of things. just have it dyno tested.
98 Civic EX
are you trying to figure which way to go?
9
i agree on second thought I dont "thing" 160 is possible either on those setups.
I apologize for the exagerated (sory cant spell) coment at least you didn't use this face
:bigrofl:
so I dont feel quite as bad.
let us know when you have the results
9
hp at the flywheel is what I was talking about. not at the wheels.
C
ok but before spend a lot of money ist good to know the result before
Civic turbo Hx/Ex
It is good to know before, however, its super tough to make a HP or 1/4 mile time estimate. Every motor is different and tuning is the key! If you are a super good tunner and have a strong motor then you can yeald the max, but a crappy or no tune and rings that are on the way out the door you may loose HP. Get what we are saying here? We aren't trying to flame you, just trying to show you the light.
Good luck with the build!
98 Civic EX
now...if you asking which setup to build, then that would be a different story...we can use our past expereinces to help you decide which direction to go...
C
ok thx guy.I will start the first project in a couple of weeks and if the result are good I will do the second.
1 - 17 of 17 Posts
