1 - 4 of 4 Posts
S
How much whp I may get from a ZC DOHC with turbo, and just running stock internals alone? how much pounds of boost I need to achieve that whp?
thnx
Lifetime Awesome Member
'89 CRX HF
the amount of psi will all depend on the turbo, dont base your hp goals on psi. 10psi on a t3 will not yield the same results as 10psi on a t3/t4
ill say psi a few more times, since it sounds wierd reading my post
psi psi psi
C
Depends on tuning and how good the condition of the engine is to begin with. 200 whp is a # that is very safe and has been reached by many. But a well tuned motor is the key
1 - 4 of 4 Posts
