1 - 20 of 21 Posts
01 Ford Focus SE
I was wondering if anyone knows how to remove the wrist pins that hold the piston to the connecting rods for the D16Z6?
01 Ford Focus SE
so there are no clips that help hold them in, just press them out?
01 Ford Focus SE
so just heat the pins and then do they have to be tapepd out or will they just slide out? also, how hot do they have to get?
C
bring them to a machine shop and get it pressed out.
heating is for installing, you heat up the pistons, so it expands then you pop the pins in, if you heat it with the pins in, i think they pins would expand too...never heard of heating the pistons to get the pins out though...so it might be possible
but you should take it to a machine shop
you ZC is a pile of junk then, honestly.
That or your using floating pins on a press fit piston/rod. Your cylinder walls will explain in short time/
01 Ford Focus SE
I read in a Honda book that they have to be pressed out, it didnt say anything about heating them.
9
you have to heat the RODS to install.. NOT the piston.. they float in the piston..
Ikillyoutillyoudiefromit
07 Si Sedan
92SIvic said:
they float in the piston. they're solid with the rod.
Actually the opposite is true. It doesn't make sense to have two friction bearing surfaces (piston pin holes) as opposed to one (rod). Think about it.
01 Ford Focus SE
yeah, the pin is fixed to the piston and the rod floats on the pin. becuase you can take the rod and slide it back and forth
9
dude have you removed your pistons? i just finished rebuilding my whole z6.. the pins floated on the piston. NOT THE ROD.
01 Ford Focus SE
so all you had to do was heat the rods and the pins slid out? what did you use to heat the rods and also it doesnt ruin the rods if you heat them, i was going to probably reuse my rods.
1 - 20 of 21 Posts
