1 - 9 of 9 Posts
I've been doing this for many years and I haven't really done a write up on it. The way I do things are probably the opposite of "bolt on."
I started in megasquirt about 10 years ago. I like the hard core diy community there. Coil on plug mods are more common these days but it was 2008 and I do my own thing. I didn't do this for performance; just to get rid of the distributor and as a fun project.
Here are some pics of the first running trigger wheel setup.
PICT1261 by rabidflickr, on Flickr
PICT1807 by rabidflickr, on Flickr
Here is the D17 setup for comparison. There are four TDC teeth and one cylinder 1 trigger. Honda uses the crank for rpm and these five teeth on the cam for timing the spark and injection. Megasquirt does support this setup now.
PICT1249 by rabidflickr, on Flickr
My early prototype used a crank sensor from a D16y7 which is a vr type. The D17 engine uses hall sensors. The vr type create a signwave like signal and the hall make a 5 volt digital signal. The vr sensor creates a very low voltage when the teeth are moving slowly and it had to be put very close to the teeth to overcome the noise at cranking. Once at high rpm it would hit upwards of 800 volts! Crazy but the megasquirt didn't care.
I upgraded the cam and needed an adjustable pulley.
IMG_20121126_204436 by rabidflickr, on Flickr
IMG_20121126_204504 by rabidflickr, on Flickr
IMG_20121126_204533 by rabidflickr, on Flickr
IMG_20121216_171314 by rabidflickr, on Flickr
IMG_20121219_213613 by rabidflickr, on Flickr
So then I set my engine on fire... http://www.d-series.org/forums/showcase/256690-so-happened-i-set-my-engine-fire-2.html
It was time to change to the hall sensor type. Hall sensors don't care how slow the engine is cranking it will still read the rpm with the same 5 volt output as 8000rpm.
The D17 for reference
20140927_142319 by rabidflickr, on Flickr
20140927_142513 by rabidflickr, on Flickr
I bench tested two different hall sensors. One generic honeywell and a stock D17 cam sensor.
20141008_203457 by rabidflickr, on Flickr
I went with the honda sensor because it fit better. Go figure. Here is the adapter plate. You can't see it but the other end is attached to that little I shaped part sticking out of the head. Also there was a lot of glue involved.
20141019_164236 by rabidflickr, on Flickr
Lots of wiring.
20141110_175419 by rabidflickr, on Flickr
Love the Civic
When I see these done right it fools me how simple it looks, then I see what goes into making it work and I am amazed any one does this. Looks rad though man, I would love a coil on setup some day on my civic. Had it on my volvo and I can see the benefits if I was FI, or tuning for a performance NA setup.
Well there are bolt on ways of doing it that take the work out of it. They are spendy. This cost me less than $150 to do the mod. But it was a lot of work.
1 - 9 of 9 Posts
