1 - 19 of 19 Posts
How can you get the rod caps off easily when plastigauging? the only thing i could think to do was put the bolts in and tap them gently...
but i think its squishing the strip a bit.
any ideas?:hammer:
racist-bigot-sexist-homophob
sawzall
Reactions: remoer
i couldnt get mine in between the blades of the crank... but i wanted to really bad. hehe
did u use a smaller hammer? they have those ones that are yellow one side, red one side...
now that i think of it, if the rods are completely straight up i could prolly have a lot more success.... grr
learning process ill tell ya.. easy to get tired and overlook obvious things.
Use a block of wood or something soft like that, hold against rod cap, bang on end of wooden block.
Remove the one bolt and unscrew the other. Pick it up about 2" ,and use the bolt as a lever.
Paint FTW?
whatever runs....
Paint FTW?
whoa, prolly gonna wanna line hone that sumbeaatch...lol
^lmfao!!!
Reactions: beater90
See above...
My rubber mallet's head is like 4 inches round on each side...I didn't have much problem removing mine after the Plastigage was done.
1993 Cobra
gab the piston firmly with both hands and bite down on the rod cap, then pull it apart! Works like a charm.
1) remove the nut
2) tap on the stud with the handle end of a hammer
3) play catch
1) Leave nut unscrewed at end of the rod bolt to protect the threads when hammering (tapping). Be careful using a rubber mallet that can chip off and contaminate your block.
2) tap on the stud with the handle end of a hammer :TU:
3) remove nuts and rod cap
4) cover rod bolts with protector (i.e. small hose or commercially avail product) This will avoid damaging your bearing, journals, and cylinder walls when the piston slides out.
5) push out piston with handle end of the hammer into awaiting hand
well its a bolt system.. and if i tap down it will squish the plastigauge strip...
but a friend suggested putting the strip on the bottom and doing the same thing. seems like a good idea.
i would use a rubber mallet
something to think about-
i wouldnt suggest useing plastigauge...it can vary in viscosity and give false readings, also if you have a thin film of oil on the crank journals the plastigauge with spread over it also giving you a false reading.
if your in a pinch then its ok to use, like if the motor is in the car...
i use a micrometer, and i have never had too tight of oil clearances or to loose (which will reasult in excessive windage, windage=less power).
thanks,
-jack
strip on the long rod side, tap on the rod bolts, cap comes off without crushing the plasticgage strip.
How simple is that?????
OH YEAH, failure to clarify if your using OEM style ARPs or Eagle/TT setup.
Yeah small issues.
Like programming a satelittle in feet, but it lands in METERS burying itself!
Okay, okay check this out. The Mars lander...I did the calculations in feet...but I programmed it in meters! Oops! So instead of landing, fucker buried! 180 million dollar, whoopsie! Two years, SPLAT! Oh, oh, this is great, this is, shh, shh...the Hubble telescope...I forgot to put in the lens! *covers one eye* "Read the top line for me?" "Uh, Alpha Centauri, uh...Sirius, the rest is just a black hole!"
1 - 19 of 19 Posts
