1 - 11 of 11 Posts
ok i will be hot tanking my bare head along with the rocker arm /lost motion assembly a few things before that, on the cylinder head below where the dizzy goes from left to right is i believe the heater hose connector, some kind of sensor plug that looks like a polished nipple and a plug connector which i believe is the thermo sensor or switch? besides that thermo switch do i need to remove that sensor that has that polished nipple looking thing can someone tell me what its called i looked for it in the manual and couldnt find it ill try to get a visual
See above...
Water sensor or water temp possibly... It's brass or something easily bent/broken and I need a need one after I took mine out. If it can be left on, do it!
I forgot what it's technical term is, but it's the sensor for the temperature gauge on the gauge cluster. it's in the haynes manual, with a procedure how to test it.
No.
It will not hurt it unless you put it in the wrong hot tank. I put a b16 head in the wrong tank at work one time. Almost lost my job. I was new and didnt know witch was steal and witch was alumminkhtgehdkdh!
ok how about the sensor to the far right i am assuming you have to take that off, i just found out about, jet spray wash. which is what ill end up doing since its less expensive along with inspection for craks and warpage.
CRX, Wrangler
I'd take them both out. It's better to be safe then sorry... and it will only take you a few seconds to remove them both.
There's no o-rings or crushwashers behind them. It's as easy as removing them, and putting them back in.
-Des!
See above...
Yes, remove that one to the far right...but be very careful with that "brass"-like one in the middle. You'll twist in and it might just apart on yah.
well ill take the one on the far right off and cover the temp gauge sensor up as best as i can. ill probably end up jet washing rather than hot tank
1 - 11 of 11 Posts
