1 - 15 of 15 Posts
there is a hole in the intake manifold [manifold from p08-3 which is a D16z6/y8 i think but not sure]the motor is a D15Z1vtec-E. pic show tha coolant line but no were it go wat can we do
can we plug tha hole or do we have to plug it sum were
98 Civic EX
there ahould be another hose coming from the pipe that runs from the warer pump to the thermostat housing, it should connect to this point.
Discussion Starter · #7 ·
This is the D15b7, the old motor that we took out. and we took the intake manifold from this one and put it on the vtec-e motor.
to this motor..
NOTICE THE OIL FILTER!!..basically all i want to know is, what do i do with the pipe circled in the first pic
Discussion Starter · #13 ·
look at this setup and tell me if this would work...remember we only have 1 water pump inlet, because of the d15z1 block, were will all the iac lines go after? and one last important question, in the first picture, can i just throw a hose on it and not connect it to anything and let it hang?
1 - 15 of 15 Posts
