1 - 4 of 4 Posts
C
Where am I going to attach my hood pins too on the chassis? Thanks
C
when i did mine, i attached them next to the light.
what year... there is a set of holes near the light that need to be widen out a bit if you ahve larger pins... but i put flat washers under ming and drilled away on the 96-2000 that ive done.. than mark the holes from the bottom... use a very tiny drill... than masking tape over the tiny hole and get the same size bit as your pins... than drill away from the top so there is no marking of paint or carbonfiber if you have too!
1 - 4 of 4 Posts
