1 - 18 of 18 Posts
Ok guys I know everyone or almost everyone will say go with a chipped ecu, well ok then, I have a 96 civic ex, I know I need a p28, the conversion harness and then what, I think its called the s200 from hondata....?? what is this all about??? what do I all need to buy?? inform me!
D
just do a search on google there are some pretty cool sites that have alot of info! I think S300 is boost ready but I dont know too much about them yet Im researching too LOL
if your going w/hondata you can get s200 w/boost option..
or if you know the tuner in your area for hondata he can unlock those features for free for you. all the features are built in...just locked from when they install it...little secret..;)
nice, so I just need to buy the s200 with the boost option, is it a kit that needs to be wired in the ecu then?? Is that something my tuner can do?? Is is better off that I have the p28 pre-chipped with the p2p files or should I just get the ecu and just buy the hondata unit and have my tuner do the rest??
if you have a VALID hondata dealer in your area...its basically another ECU..
i think you need to do some reading on their site right quick..
and get to know your local hondata dealer...because if you befriend him...he can unlock features for u that you are supposed to pay for...like a boost option....
www.hondata.com
Reactions: modsHXcivi
www.hondata.com
ok Ill look into it..... thanks Paul
Administrator
93 cx hatch
i thought hondata s200 was isntalled into your ecu?? and its liek a box or somethign so to say on the outside of the ecu?
i thoth s300 was directly installed inside of the ecu
ryan89crx said:
Hondata vs Emanage??
there is NO comparison...
well for me there is, I am planning on going hondata here tho.....unless my local tuner can tune uber....
one of D-series.org's nicest rides
s200 comes with a interface box that plugs into the ecu, s100 and s300 fits in the ecu
R2.....Zap Balls
94 Ex coupe
s200 is $500 with boost option, s300 is $595 for everything. Check for NEPTune dealers in your area, it does the same thing as the s300, but from I've found so far it's cheaper
Discussion Starter #18
mikeD16Z6 said:
correct me if I'm wrong guys but dont you still need an obd1 ecu to run hondata?
yep, Ill need a OBDI ecu, still to get if I do go hondata, or even uber.....
1 - 18 of 18 Posts
