1 - 11 of 11 Posts
I haven't had a Honda/Acura in nearly 2 years, and I need to make some more room in the garage for the new bike, so this stuff needs to go.
All prices will be without Paypal fees or shipping unless otherwise noted. This stuff needs to go, but I am not looking to lose my shirt over shipping. I will work on getting some generic rates if there is interest in this stuff.
Endyn (Moroso) catch can with -10 AN adapters. 35$
-10 hose with one straight fitting and one 45 degree fitting attached and two 90 degree fittings. $40
Buy them together for $65
2 Innovative mounts 65a replacement pucks. $7 shipped USPS first class
RDX injectors with approximately 18K miles on them. They include the 11 mm inlet adapters and Toyota clips. SOLD
GE LSV adapter sandwhich plate with -6 AN supply line. Could also be used for turbo oil supply. SOLD
NOTE: Add still in progress.
only the injectors are loading for me
glws
Discussion Starter · #10 ·
what size are the injectors
Rated at 410 cc/min at standard test pressure. Crank up the base fuel pressure which (this style core responds well to it), and they will flow over 500 cc/minute. If you do some searching around you can find flow sheets for these injectors.
1 - 11 of 11 Posts
