I may have an opportunity to get some Fit wheels but it may not work because they have a 55mm offset and most honda's have 38mm-42mm stock.
we tried installing the same wheels on a 96-00 civic but at the rear the wheel would not clear the upper control arm, only buy 5mm-10mm. now my question is would i run into the same problem or could i use a spacer on the rear to clear???? btw the car is a 91 rex....
