21 - 38 of 38 Posts
Discussion Starter #21
Err. Just take down the number at the end of the link and replace it once you reach any product page on the website's store
thanks just did...i wish it would say what its for....
Discussion Starter #22
any one else have any more info on this???
Think I fixed it..
OBD1 ECU side
APM/TYCO
female small contact = 175026-1
AMP / TYCO 175026-1 is in stock! | Buy 1750261 | 175026 1 | Onlinecomponents.com
female large contact = 175061-1
AMP / TYCO 175061-1 is in stock! | Buy 1750611 | 175061 1 | Onlinecomponents.com
Housings
small 16 place = 174514-6
AMP / TYCO 174514-6 is in stock! | Buy 1745146 | 174514 6 | Onlinecomponents.com
med 22 place = 174515-7
AMP / TYCO 174515-7 is in stock! | Buy 1745157 | 174515 7 | Onlinecomponents.com
large 26 place = 174516-7
AMP / TYCO 174516-7 is in stock! | Buy 1745167 | 174516 7 | Onlinecomponents.com
Sumitomo
sensors side female =CONN-11656
Home » Shop » Connectors / Harnesses » Sumitomo » Injector Connector Terminal (22 - 16 gauge) [heat resistant copper alloy]
RDX injector females =CONN-11856
Home » Shop » Connectors / Harnesses » Sumitomo » Sumitomo TS / SL Female Terminal 0.5 - 1.25 mm2 ( 20 - 16 AWG )
I still am looking for the male pins that are used in the sumitomo housings
JAE ... for the green plug under dash on the 96-00 civic
small female contact =IL-AG5-PC1-5000
Digi-Key - 670-1790-1-ND (Manufacturer - IL-AG5-PC1-5000)
wire. mil spec
Aircraft Wire, Tefzel & Teflon, RG400 Coax for Aviation & Marine
loom & wrap your choice
https://www.wirecare.com/index.asp
Cable Management, Electrical Supplies and Friendly Service at CableOrganizer.com
crimp tool
Home » Shop » Tools » Crimp & Strip » Standard » Wide-Range Crimper Delphi / Packard 12085271 Replacement - Excellent for crimping Weather-Pack ( Weatherpack ), Metri-Pack ( Metripack ), GT Style and most Terminal Types *RECOMMENDED*
extractor tools... = nice but not needed made my own but ended up getting a free one.
Home » Shop » Tools » Removal Tools » GM Type Metri-Pack ( Metripack ) and GT Removal Tool - Thin Blade ( 150, 280 and others )
Home » Shop » Tools » Removal Tools » Delphi Metripack Removal Blue Tool, thick blade (MP 280, 480, 630, 800)
just an idea of the type of PDFs I had to weed through
http://jae-connector.com/en/pdf/2008-111-IL-AG5.pdf
go ahead without part numbers and try to find any of the AMP/TYCO items on the website
Electronic Components and Systems that connect, protect, power and switch from Tyco Electronics
Discussion Starter #24
thanks man it works now^^^...did you buy any of that stuff???
Nope, all this info is from a friend who did his own wire tuck harness for an obd2b car with obd1 ecu.
Discussion Starter #26
so your friend order this stuff then??? can you find out how he like the terminals and plugs?? just want to know how close to factory these are...thanks man
Think I fixed it..
OBD1 ECU side
APM/TYCO
Housings
Sumitomo
wire. mil spec
crimp tool
Got any part numbers for AMP/TYCO that are on the ECU side? (female)
Discussion Starter #28
still looking for obd1 and 2 dizzy,alt and male shock tower pins
21 - 38 of 38 Posts
