1 - 20 of 22 Posts
· formerly Kit88
ek hatch
How much hp´s and 1/4 miles times could I spec with my set up??
Del Sol S 93
d16z6 turbo at 15 psi
apexi manifold
apexi turbo Ihi rhf5 ball bearing
3" down pipe
2.5 exhaust no cat
fmic
2.5 intercooler pipes
innovative wide band oxigen sensor and gauge
1st gen dsm bov
59300 cam
20x8x13 slicks
p06 chipped with uberdata
450 cc dsm injector
walbro fuel pump
no ps
Also, do I have to make some suspension upgrades???
I have eiback springs and kyb agx´s
Please advice.
Honda
no one will be able to tell you what you are going to run in the quarter mile. It all depends on how well you can actually drive, and also how well you tune your setup. you could have the best setup in the world, but without a good tune, you wont go anywhere with it. As far as power numbers go @15psi, i would say anywhere from 230whp - 300whp, but again, it all depends on the tune.
As far as suspension, it will definately net you some better times. especially if you have stiffer rear spring rates. I would look into some traction bars thoug, especially with those slicks.
· formerly Kit88
ek hatch
Discussion Starter · #4 ·
Honda
· formerly Kit88
ek hatch
Discussion Starter · #7 ·
Sorry, I miss this on my set up descrption.
d16z6 block
vitara pistons
eagle rods.
Honda
15psi on a stock block, hope you tune it well cause your gonna end up shooting a rod threw your oil pan!!!
:shocked: Holy moly, i didnt even see that. I guess i just assumed.
But yeah, man, you definately need to not skimp out where it matters most if you are going to be running that much boost. With an excellent tune you could make 220whp for a while without blowing it. With a good tune, 200whp. With a shit tune, drive your car off a cliff and if it survives........if it does then congratulations, but you still have a shitty tune.
· formerly Kit88
ek hatch
Discussion Starter · #10 ·
MMMMM, i was thinking that a 15 psi I could be about 250 whp.
Thanks for your feedback guys, your experience is always welcome.
Honda
http://www.turbod16.com/album_page.php?pic_id=3345
14 psi made 307whp. Im assuming the head was stock but the block is obviously built. But those numbers were on a SC34 turbo................
but that just shows that anything is possible
· formerly Kit88
ek hatch
Discussion Starter · #15 ·
Thanks guys,
waiting for more comments !!
Honda
Thanks guys,
It could be done with uberdata??
uberdata will do it. Anything that you can adjust your fuel, boost, and timing maps will get you what you need. i reccomend crome because i have heard better things about it. Even better crome pro, but it costs $150
Honda
You should have around 1000 horse power, should be hitting low 3's Im not great with math but im sure im right.
:liar:
are you sure about that? Im pretty sure he will be making just a tad over 1000, but i dont see low 3's, i see mids.
Honda
I told you I suck at math.
hey its all good. I figured it was a rough estimate anyways. When your dealing with that much power, its hard to predict accurately anyways. :TU:
1 - 20 of 22 Posts
