G
·Hi,
I have a Rover 416 with a Honda D16A9 engine in it - it does not have a CAT or lambda sensor or OS2 sensor.
(1590cc DOHC)
When the car is warmed up, when I go to change gear or stop the engine often cuts out. Even if it doesnt cut out it spends 3-4 seconds at 300rpm before picking up.
The problem doesnt occur when the car is cold; the car also drives just brillaintly and when it does cut out it will immediately restart but often cuts out straight away - cant find idle.
I have:
- Adjusted then changed the throttle position sensor (TPS)
- Tried various base idle positions
- Tried adjusting CO2 to see if different fuel mixture will help (also changed IMA adjuster)
- Changed MAP sensor
- Changed coolant and air temp sensors
- Changed atmospheric pressure sensor
- Changed the IAC / EACV
- Changed the ECU
- There are no codes on the ECU
- Cleaned the throttle body and Inlet manifold
- Done a compression test
- Done a head gasket test
- Changed the timing belt
- Checked the ignition timing
- Checked for vacuum leaks
- Changed the HT leads and the distributor (including coil, amp and rotor-arm) ** changed this about a year ago cos of other problems - so I wouldnt have thought it could be this????*
- Gone mad
Any ideas please?
Someone out there has to know what this could be
(1590cc DOHC)
I have:
- Changed the ECU
- Gone mad
Any ideas please?
