1 - 14 of 14 Posts
Hi all, I would like to introduce my Honda Civic EJ9:
  • Engine is D16Z6
  • Modified cylinder head
  • PG6 pistons to raise the compression ratio
  • Intake - horizontal + Simota
  • Exhaust - 4-2-1 exhaust manifold, 60mm pipe and custom muffler
  • Radiator - aluminum 3-row
  • Pipes - silicone
  • Oil cooler + spacer + thermostat
  • S20 gearbox with 4.4 gear ratio.
  • 260mm front brakes, 200mm drum rear
  • Suspension - Tein MonoSport
  • Rear cross-arms Skunk + plate
  • Rear stabilizer 22mm
  • Wheel extension spacers 15mm
  • TE37 replica and Kosei K1 wheels
  • Front stabilizer 26mm
  • Front camber arms HardRace
  • Shorter steering rack with enlarged camber (2.87 turns +3 degrees of camber)
  • Custom X-bar
  • Weight of the car is exactly 1000kg.
  • Two bimarco buckets
  • Schroth Racing Profi II 4 asm FLEXI belts
  • Steering wheel OMP Superleggera
Car is prepared according to the technical regulations of Time Attack competitions in Ukraine
137980
137979
The EDM civic MB4 fastback comes with OEM 4.437 a very hard gearbox to find.
MB4 D16W4
1 - 3,250
2 - 1,782
3 - 1,172
4 - 0,937
5 - 0,750
FR - 4,437
there are different gears for the steering? holy shit
Reactions: Stefanzoh
its all <3
Reactions: patxi
Discussion Starter · #10 ·
sweeet
How's that close ratio steering? One modification I definitely want to do to mine.
I don't know exactly about all the details, but we have an expert in Ukraine who can do different versions of shortened steering racks on ED/EG/EK/EJ/MA.
For example for EK he can make:
dry rack
shortened rack ( similar to EK Type R)
shortened dry rack with power steering option.
etc.
Very nice, I like the motor and brake choices 😍
2000 Honda Civic EX Sedan
Car looks like it's ready to do business on the track man. I've always been curious about the Honda scene in other countries. What's it like in the Ukraine?
1 - 14 of 14 Posts
