21 - 21 of 21 Posts
The Great Weldini
91 civic
Discussion Starter #21
A quick little tidbit i encountered:
when installing a 94-01 Integra rear sway bar into a 96-2000 civic, the Teg endlinks will not match up to the holes in the RCA's for a 4 door civic. neither will the teg brackets, as they are for a varying depth subframe. you must use SI subframe brackets and si endlinks to make it work. Just as long as you have the correct R/LCA's. if you install 94-01 Integra R/LCA's you will only need the subframe brackets. But i have a 4 door sedan, that actually didn't come with a rear sway bar, but had the LCA's with the bolt hole in them.
Not sure if that was touched on already or not, if so i need to read more carefully. But i figured i would chime in anyway.
yeah i forgot to correct an error i made. after 95 thr 96-00 they cahnge the subframe so the way things bolt up a way different.
21 - 21 of 21 Posts
