1 - 6 of 6 Posts
91 crx HF/67 jeepcj5
i got a turbo timer from a friend and i dont know if it work is there anyway to test it? it got 6 wires coming out of it ?
'02 Civic LX Coupe
For what it does...I know that some can record 0-60 and 1/4 mile times, but other than that they keep the motor running on a timer after the driver has shut it off to keep oil circulating over the hot turbo compontents. The motor then shuts off after the timer runs out. Idk what else they can do, probably a lot.
R2.....Zap Balls
94 Ex coupe
hook up power and ground to it. Set the time to about 2 min and then take a test light to check to make sure the other wires have output.
1 - 6 of 6 Posts
