hey all,
as some of you may know im running a HKS Supercharger on my gen1 crx.. its running as of friday night.
I took it for a drive yesterday just around the block couple times and im experiencing the following issues:
a: its slightly overheating
b: bogging down on low rpm but not above 4-5000rpm
its a D16A3 motor running vacuum advance, im guessing the overheating could be cause by 1: air in the system 2: incorrect ignition timing. im guessing also that the issue for it bogging down could be due to the timing or too much fuel pressure on low rpm.
Fuel pressure is set to 40psi (book suggests 35-41psi)
any ideas are muchly appreciated
Mike
Mike
