1 - 16 of 16 Posts
ok so i put this bov on my car without a fin but it sounds like im gettin back spool? is it suppose to sound like that from no fin or do i need to run the fin??
the "sound" is fast doesnt make a gobble sound..just a fast similiar gobble PSSSHHH!!!
idk what "fin" your talking about... maybe the horn for the bov??
either way i head that HKS bovs commonly have a flutter sound to them, your probably fine... mine sounds the same way
1992 Civic Si
It's normal and it's not going to hurt anything. The SSQV (even legit ones) open slowly, so there's always a little flutter when you're running higher pressures.
This is what my ebay one sounds like with the fin removed.
under about 2-5lbs sounds like air but under 12lbs has that flutter noise..i was hopin it wasnt back spool..sounds sick :p
1999 EJ8
Your fine, it should sound like that without the fin installed.
Once I heard Sentry's BOV without the insert, I took mine out and it sounds the same as his.
For some reason my friends said the BOV sounded better with the insert, so I put it back in. For now.
But yes, your fine.
1 - 16 of 16 Posts
