1 - 15 of 15 Posts
title says it all... just looking for some affordable freakin pistons because everything else is ridiculously expensive : \
Start at about $1000 for the rods, pistons, machine needed for the pistons, D15B VTEC crank, Cometic head gasket, etc.
Helping build a SCCA F Prod/NASA Perf. Touring motor with 12.2:1 compression.
Defender of the D
ok that takes care of the rods, now for the OP's question about pistons.. idk i'm in the same boat as u... BUMP for an answer.
will the gx piston not work? i got this from the zeal calculator...
Only if you have a JDM D15B or using Z1 rods, I'm assuming you have the JDM D15B VTEC? If so, it should work fine unless you run into valve-clearance issues.
Also, Transzex, he's asking for OEM pistons.
I got Bit by the Boost Bug
I did everything you did on the Zealworks but only thing i changed up was the pistons,I changed them to p29's and it gave me an effective ratio of 16.5:1???That seems high for what i entered.
Not terribly expensive, but not cheap either. try www.hondaautomotiveparts.org
$198.94 Shipped for STD pistons
$145.46 Shipped for .25 OS pistons
$198.46 Shipped for .50 OS pistons
$122.66 Shipped for OEM rings for any size.... Bought all together should lower shipping a bit.
Discussion Starter #13 (Edited)
thx, great responses! was def looking at those fjt rods... the engine i'm using is more of a z1 clone d15b (the vtec-e) but i'm pretty sure it's the z1 spec crank and rod size... i hope :S well i guess this will be something of an experiment lol
compression height on p29s is also too great for the d15 deck, according to the calc a z1 spec engine needs a 27.75mm height piston to be flush with the deck and the PMS is the closest fitting dome piston
1 - 15 of 15 Posts
