1 - 4 of 4 Posts
97 EX Civic
What can I do to get higher compression other than replacing pistons. I have a y8 engine
Replacing the pistons is the only practical way to do it. You can do a few things to bump up the compression, but not by much. You could deck the block or shave the head (as stated before), you could replace the valves, get a thinner head gasket....or you could even work on building up carbon deposits in your combustion chambers ;).
1 - 4 of 4 Posts
