1 - 7 of 7 Posts
I
Hey i have a high idle on my g1 (it idles roughly at anyhwere between 1k-2k usually at 1500) anyways im replacing my vacuum lines here soon and i have alreayd tried adjusting the throttle cable or w.e..so if the answer isnt the vacuum lines what could it be? i have 2 exhaust leaks but im not sure if that could effect the idle. what should i check for if the vacuum lines dont fix my problem?
W
ummmm what have to done to it to cause high idle???
W
yea maybe but it doesn't just high idle what did you do???
IACV will cause it to idle up and down not just high....As mentioned what have you changed or done to the motor? Have you adjusted the timing/idle at all? Turned the distributor to advance or retard it etc.....
I
nope...just one day it decided to start idleing at 2k...now that the weather has gotten a lot cooler it idles at like 1200...i havent done any engine work just suspension....
W
yea ima say the iacv. take the plug out to it does it idle fine if so your problem is there
1 - 7 of 7 Posts
