1 - 6 of 6 Posts
crx
my car has always seemed to had a low idle since i bgot it and now i have a high idle after doign soem maintenance and returnign parts to stock. i had decided to change the fuel filter and in doing that i broke the fuel pressure gauge plus the fitting that was used for that gauge was weird and didnt want to tighten rigth. so whiel i was at the junk yard i picked up the right bolt for the fuel line and a stock fuel pressure regulator. i have an obd0 ecu but the injectors are obd1 so i picked up a regulator from z6. i had bosch platinum plugs but i switched to ngk due to lots of godo advice. i dont seem to have any vacuum leaks at all btu the idle is high around 1100 - 1500 once warmed up and it varies. anyone have any suggestions?
Ply with the air bleed screw on the throttle body. Check for vacuum leaks. Do you have any codes?
wrong injectors for ECU....
What year Ford motor into a Pontiac with GM fuel system??????
We need details........you need to clean your typing up a little. Doesn't have to be perfect....but don't make our brains hurt as well!
crx
it went back down.i have a 89 crx. it uses a obd-0 ecu with obd1 injectors with no resister box. the car runs good but the idle sucks it fluctuates and its real low. after i did all thsi maintenance this weekend and fixed a wire behind the seat the engien light doesnt come on anymore. i think ill change the idle valve next.
1 - 6 of 6 Posts
