1 - 10 of 10 Posts
Now when the car is cold the car will idle at 2500...when its warm it will idle at about 1500. The motor is a vitara z6 block with a y8 head. I have a z6 adjustable cam gear but it was the y8 cam + head so I advanced the timing 4.5 degrees. No vacuum leaks. The dizzy is in the middle. I'm not sure what else it could be. Could it be the timing?
2001 TL1000R
vitara build-is it tuned yet? if not i'd retard the timing till u are @ the right idle(use the dizzy) @ least until its tuned(like i said IF its not already)
1988 Honda CRX
You cannot idle faster than the air entering the engine allows. You have some sort of air leak somewhere.
same
check the Idle screw on the TB check the TB itself ight be open or a bad TPS
93 Si hatch
yeah check ur timing, your vacumm hoses,your intake manifold sensors,the wiring on them not frayed or reading good on the multimeter,if nothing you can check your intake manifold gasket
1 - 10 of 10 Posts
