ive done some searching around and ive found a couple companys that make d series high compression piston... anyway, the setup im looking forward in building will be a d16z6 w/ itbs, rods, stock crank, crower 3 cam, crower springs + retainers, crower +.5mm Valves... thats just a little run down, the question issssss; if this was your car, what brand of pistons would you throw on it and what compression. keep in mind this is going to be a daily driver w/ autox&drag on the weekends... aaaand mpg is not an issue with me.
