1 - 20 of 22 Posts
C
Hi.I'm from HK.Start to do a DOHC ZC project really needs your help
there's is really no racing parts in hk
anyone can tell me can dohc use d16z6 or d15b vtec cam gears
or can use b16a cam gears without modification?
What enigne's manifold can use on my engine?
how can i modified h23a,b16a,h22's intake manifold to use on my car?
how can i modified b16a,h22's throttle body to use on my car?
can i use b16a's igntition coil in zc dohc?
besides, can i use d15b's piston on zc dohc? they have the same bore
Why the eingine will be broken if i use d15b piston on a ZC dohc??
thanks so much
i really really need your help
since there is lower than 10 zc engines in hong kong
someone told me that b18a,b18b,h22a,h23a,f22b,f20b intake manifold can blot on right
Welcome.
I assume there will be some problems with using other cam gears.
Manifolds would have to be machined and port matched.
Throttlebodies should bolt right up. I have a gsr tb on my d16a1.
Administrator
93 cx hatch
i believe there is a diy on the site about fitting b16 cam gears, author would be top aussie
only parts other than that i think your gonna be able to get to work are throttle bodies. i know manifolds do not line up
C
thanks
[/IMG] Really thanks thanks and thanks to you all big brothers
there is extremely few ZC dohc engine here
not to mention any racing parts
so i don't know what is JG cam gear
it is better to use sohc cam cam gears or b series cam gear ?
d16a1 is sohc or dohc?
you mean i can use b16a tb on dohc zc?
b16a inatake maniflod can be use after porting the pipe entries?
any one know dh racing is worthy to trust or not?
besides, no body use msd product in hong kong (what a pitty) so i can't buy one
some people from taiwan said that accord coil core can change to use in dohc zc's cap
C
gsr tb means tb from b18c or b16a?
can direct blot to my ZC dohc?
which site talks diy about fitting b16 cam gears?
thanks so much
D16A1 is DOHC.
Yes you can use a b16 tb.
Not only do you have to have some move the ports but port match them. 2 Steps.
GSR is B18C.
Yes, just get a new tb gasket for it before installing it. Might want to clean it up if used/dirty as well.
C
really thanks for your advice
can i modified to use b16 intake manifold also??
thanks again
there rreally isnt any intake manifold that will work with the zc motor besides the zc one and the d16a1/2/3
the b16 will not work with heavy machining and its not worth it cause the zc has very good intake manifold already
u can however port the runners and plenium of the zc intake manifold and make it even better
C
thanks
10 million thanks to you again
dohc has a great manifold already?
its throttle bodies is 60mm original
but my target is to get a 68- 70 mm Tb
besides,its good if i can get a b18c installed into my engine,since porting of intake manifold and tb to enlarge the lumen is limited
i wish to get a big manifold together to use with aggressive performance cams
Actually the ZC, D16A1/A8/A9 are 55mm tb. The gsr one I have is 60mm which the same for the B18B1, B20Z and the B16s. B18C5 type r and s2000 have 62mm, but are rare finds.
Stick with the ZC manifold as stated above. I love my d16A1 im, long runners and a large plenium.
Crespo makes cams in stages 4 and 5 for our application.
http://stores.ebay.com/CrespoCams_Camshafts_W0QQcolZ2QQdirZQ2d1QQftidZ2QQtZkm
H
The aftermarket company Skunk 2 has adjustable cam gears that'll fit on the ZC. They are generically labeled as B16, B18, H23. So if you can use ebay or find a supplier that can ship them they are one option you have.
JG is another brand of adjustable aftermarket cam gear that can be used. Search for either one of those brand names on ebay perhaps or a direct supplier. Good luck on the ZC build.
C
Discussion Starter #13 (Edited)
we use JDM cars in hong kong
gsr tb is 67mm here and zc is 60mm
i love Crespo but is it good to try dh racing?
C
thanks
i will buy gears for b16a
i hope i will have good luck since no people knows about dohc zc in hong kong
Never heard of dh racing, but hey everything is worth a try if your limited.
Oh how I envy you...67mm? I can only imagine a type r tb. You should start selling some of them online!
C
Discussion Starter #16
yea
it quite strange that spoon tb from japan is 70mm, only 3 mm larger than gsr jdm tb
but why can't i use d15b's piston on dohc zc?
thanks again
C
some ebay seller told me that b18b manifold will fit dohc zc
C
Discussion Starter #19
o
what a pitty
thanks anyway
anyone know will there any increse in horsepower with i change a better ignnition coil or change a racing spark cable?
C
Discussion Starter #20
jdm stock cam has peak power at 6800rpm
can i delay the peak to 7000-7200rpm by increasing the overlapping by adjustable cam gears?
thanks ^^
1 - 20 of 22 Posts
