Ok, so i just bought a 90 HF and I need to put a fresh motor in it. I plan on doing a SOHC ZC, which is the same as a CRX SI motor, for install purposes. What I'm trying to understand is, if i use an SI transmission and a SOHC ZC, do i have to use different axles? If so, will they work with the hub assemblies on the HF, because the spindle count is different?
Basically, what do i need?
