G
·IS there a way to get quick HP out of the HF motor what it the best way to build motor. What can I do to it to make it faster.
So what do you do when the extra 8 valves have no valve reliefs in the pistons, thereby SMACKING together and BENDING 8 valves?????BseriesKllR said:yes HF is 8 valve but by swapping to a crx si head makes it a 16 valve.
transzex said:So what do you do when the extra 8 valves have no valve reliefs in the pistons, thereby SMACKING together and BENDING 8 valves?????BseriesKllR said:yes HF is 8 valve but by swapping to a crx si head makes it a 16 valve.
UUUHHH...Same reason we modify ou cars.....MORE POWER.94x said:Your piston to valve clearance must be VERY close!!!
I would not recomend a 16 valve swap to an 8 valve bottom.
Why did you do this??!!
