1 - 9 of 9 Posts
1988 CRX HF
I dont know if this is in the right forum but I was jus wondering if the HF PM8 ECU would run my ZC, im not going to use this a permanent solution but i jus need to get the ZC started and find out if the PM7 ECU is bad or not. Any help would be appreciated.
Thank you
1988 CRX HF
Thank you Green 91,
yea its a PM8, all i have though is a PM8, I might have to go find a PM6 or a PG7. I jus didnt know if it would start the motor or not.
1988 CRX HF
Discussion Starter · #5 ·
awesome, thank you ryan89crx. I jus need it to test if the motor is gettin spark and if there is a injector pulse.
Doesn't the hf have 240cc injectors? though i'm guessing because of the 8 valves the ecu is throwing out quite a bit less fuel. w/ a fpr at like 45-50psi I would think it would work (not exact numbers).
1988 CRX HF
Discussion Starter · #7 ·
thanks guest, im not using it to run the car, im jus gonna be using it to check and see if my PM7 ECU is bad by checking if i get spark and have an injector pulse(which i dont have now with the PM7 ECU)
1988 CRX HF
Discussion Starter · #9 ·
guest, yup ive checked for fuel and spark multiple times with the PM7.
1 - 9 of 9 Posts
