1 - 12 of 12 Posts
95 coupe
I already have an alarm installed in my 95 coupe, now i want to install a remote start and keyless entry. The question is that will i be able to use one remote for all this or have to use the remote for the alarm and the remote for the starter and keyless entry?
95 coupe
i bought the car w/ the alarm already installed. On the remote it says Hornet RPN491, idk if tht helps
Tell ya what get under the dash and give me the model number off the brain not the remote
And i will see what i can do for you ..
K
R2.....Zap Balls
94 Ex coupe
as long as the alarm has a secondary output you can do it
1989 iroc
cant you get a remote start and program it for the door locks also..... or must it be the other way around
R2.....Zap Balls
94 Ex coupe
you can get just a remote start with keyless if you want and add an alarm on to it later
1989 iroc
k thanks man
1990 CIVIC
you might as well get a new one i would recomend python 871xp thats what i have had in my cars i use to install them it has some what of a delay on the remote but they are solid alarms.
if you already have power door lock is easier if not you have to get actuators in the doors first
that alarm will give you power door ;ocks
power window automation
remote start (be careful with a stick dont leave it in gear i have seen numerous cars go in to bushes middle of street because it wont stop untill it starts or it senses a voltage change )
you have 3 aux for backup batteries motion sensor you can program turbo timer with it as well so if turbo is in your future its nice to have
hope it helps
or you can have a audio sensor
1 - 12 of 12 Posts
