1 - 9 of 9 Posts
P
Ok i have a d15b6 and i did some reading on here and i curious to what head would work nice with my block i wanna build up my engine but i don't wanna do a bseries swap im trying to beat my friend with a jdm b16a in a SI rex i have a hf rex so i got him beat with weight
i don't know the b6... is it the original engine for the HF? Cause that's 8 valve, so you'd need to swap your pistons to get a 16-valve head. maybe you mean b8?
Just get a whole new engine... not a B. But a d16z6, d16y8, or even a D15B if you can get one. I have one and I like it alot. Still, you probably would have to do a little more than just a new engine to beat your friend... unless he's a bad driver.
P
yes it's the hf motor and yes he sucks at racing lol so no other head will work on this block or pistons? ...ect :???:
P
how much do a6's cost and will it bolt right in? 91 hf
D
I'd do a Z6 or a Y8 as there are tons of them out there and there are parts galore. Also, if you blow one, the bill is fairly small. The ZC is a great engine but they are increasingly rare and shops and junk yards are getting wise so the price is climbing. There are other ways to make the -maybe- 9hp that the DOHC will net after some dyno work and if there is FI in your future, after 250 to the ground, does it really matter which engine?
the hard-parker
we've missed you DseriesScience! as for the poster, I'm with makku. look for a z6 or y8 swap, and then build that. you'll net more gains than sticking with the motor you've got, and if i remember correctly it pretty much bolts right in. can anyone back this up for me??
1 - 9 of 9 Posts
