my 94ex threw a rod i have a y8 motor what is involved in making this swap possible... what ecu harness and distributer do i need i have everything from the y8 and the z6 please help..
use all the stuff from your z6 such as, ecu, injectors, dist, i think the t/b are the same...use all the wiring in the car already all should go well....good luck.
the dist wont line up that is the only problem i am having now the y8 dist i different than the z6 can i hard wire the y8 into the harness or will it not work right if i do.. and the z6 harness mdont have a plug for the knock sensor
Ok so I’m trying to tension the power steering pump where it needs to be and realized the car didn’t have part of the items needed to do so.
My question is what other piece do I need to complete this so it will stop squealing randomly?
Portion missing is piece that the wingnut bolt threads into...
So I'm going to start that I need a new starter and dizzy for sure but cause I hook up a z6 harness to a y7 block ? And I'm thinking about just getting a z6 block and putting it in
Need a second opinion here:
I have an 89 CRX Hf that had working AC, not amazing, but it worked. I assume it was R12 as there were no converter nipples going on.
A while back someone hit let head on, broke the radiator and mangled the condenser, but didn't rupture it.
I decided since I was...
Hey all,
Long time reader, first time poster.
So, I have a 1995 Civic Ferio Vi, with a D15B (two stage vtec) engine in it. Imported from Japan, so all JDM parts.
But... Something backed off the bolt on my main pulley (AKA harmonic balancer), and it got damaged. So, now to find one.
Partsouq...
