1 - 11 of 11 Posts
Cool User Title Here
I am putting together my y8 tranny (had my y8 main and countershaft in my y7 case), in its original form.
However I cannot get the ring at the end of the mainshaft to snap into place!
Anyone have any clues/tips as to why I cannot do this??
Great, just some more fun for me
Scrapped the y8 tranny, can't get the remaining bearing off of it...so I can't put it back together
Started assembly of y7 tranny
Same problem, could not get snap ring to engage bearing at end of countershaft...
Now it won't come apart
I am so done with doing my own work
mainshaft doesn't have a lock ring.............
you mean the countershaft I hope........
Spread the ring so it passes over the end of the bearing, then lower the case or use a rubber hammer. Install 4-5 bolts for a first timer, flip tranny over and the countershaft should drop into place. If not LIGHTLY bounce it on the workbench and you'll hear it click into place.
Yes, I meant counter :)
Thanks for the tip, I unfortunately cracked the 1 bearnig ni the y8, and have no way of getting the remainging bearing off at this point
Y7 tranny, is stuck together, I cannot get broken in half at this point, without breaking it
Any sources for getting a quick bearing sent my way??
30mm socket and hammer is all that is need to get the bearing off.
You trying to put a Y8 tranny back to stock?????
Hmm....that is all huh?? Just a little reverse impact to get the thing sliding??
Yes, trying to put the y8 tranny to stock, had the input and countershaft in my y7 case because of a cracked y8 case at time of install.
Just found a z6 tranny for 100$ locally. If that hammer trick does not work, it will be going in.
impact off the nut, use a LEATHER glove to hold the countshaft.......
Then hold the countershaft between 3rd and 4th gear. Hammer on the end of the shaft using a soft metal hammer 2-3 lbs, and the bearings will come off.
I have both bearings in stock.
The outer one with groove
$22 online, $27 from dealer, plus shipping.
I won't be able to ship till Tuesday, I have a out of town funeral to attend today (Monday)......Likely you can get it from a dealer in about the same time and for the same price after shipping from me.
91003-P21-003 BEARING, BALL $21.69 $5.09
Thankls for the tip! I have a donor bearing sitting in the y7 case, if I can seperate them. Otherwise I have to order one and get it here, which I will call around and see if anyone has it in stock today.
1 - 11 of 11 Posts
