Hello i need to know what tyres fit...
I can install 185/60 r14 or 175/65 r14 .
Im italian and in my country its very difficult to fit another type of wheels and tyres
would be great to know what chassis.
whatever size on 14's that equal the height of 195/55/15s will fit.
tire size is listed on driver door or on driver door jam on sticker.
use google, find tire calculator, and you can compare sizes, and find other sizes that keep speedometer about the same.
1992 to 2000 civics use 185/65/14 size
but some came with 195/55R15 lol. so he could in theory use a tire with the same height but on a 14 inch rim if he was in a pinch
yes, just stating the 98%.
195/55/15 is what are on my 99 SI alloys
Reactions: slo_eg8
Formerly weebeastie
I live in Italy, and in my country you can only fit the tires shown on the registration certificate. The only tyre can i Install are 185/60 r14 or 175/65 r 14
Just a quick search and it looks like Toyo makes a Proxes R888R tire in 185/60 r14. Depends on what you want to do with the car. If you're looking for maximum traction, I would go with that Toyo 888 or a Dunlap Direzza ZIII. Both of those tires will get good traction, but they will wear out fairly quickly.
For an every day tire that will last a bit longer, you should look at the General Altimax RT43 or the Cooper Evolution Tour. Either will last longer but will not have the traction potential of the other two tires.
