1 - 4 of 4 Posts
I recently bought a 99 civic ex an I believe I had a d16 and want to put a turbo on it before I do that what do I need before I add the turbo so I don't blow my engine??
1992 Civic EG esi
You can build a turbo kit and install it but you just can't go over a certain PSI. Which If you search, you would know would be around about 8 PSI.
a search would help you as well. psi means NOTHING. the real question is HOW MUCH HORSEPOWER ARE YOU TRYING TO MAKE. stop giving out false info.
Sloppy Jalopy
I were you I would start reading and researching about cars ...
start at the ground and work your way up and learn yourself about each part of the system that must all come together and work as one.
then do maintenance on worn out parts
brakes bjs tierods bushings lines suspension.
once all that is done it should have been long enough that you did a google search for turbo engine requirements https://www.google.ca/search?q=turbo+engine+requirements&ie=utf-8&oe=utf-8&gws_rd=cr&ei=BQVoVrijB8it-QHNiprYAghttp://
1 - 4 of 4 Posts
