1 - 12 of 12 Posts
stock rods work. Compression will be high so a correct tune will minimize the risk of detenation.
idk dude, cuz ik wit my d15 i put p29 pistons in it with a d16a6 cam and a heangasket from a 97 honda civic d16 vetec its a 3 layer gasket and i went from 9.0.1 to 11.1 comp. so were talking alil bit more power
but wat power in BHP or KW would i gain?
power depends om more than just compression, stock d16 rods are good for around 200 lbs of torque, much more than any NA build can make
you're limited to around 150 WHP in an unported head
intake and exhaust design have huge effects on overall and peak power
so does the tune and the cam
if the compression is your only mod and everything else is stock you're probably looking at maybe 10 lbs more torque and a few more horsepower
if you're raising the compression, is good to have ARP head studs.
save some ca$h. try to get ZC or 88-89 Integra pistons w/ the rods.
1 - 12 of 12 Posts
