1 - 2 of 2 Posts
By a stroke of luck I finally got a spare d16z6 block. I need some opinions on my build.
- eagle H beam rods
- vitara pistons
- 10lb flywheels
- any suggestions on cluch? I want it to feel like stock but be able to hold 350ish hp if I deside to go there.
- zex/comp 59300 cam? where can I even buy one? do I need new springs/retainers/valves?
- rc 750cc injectors?
-tranny mods?
I already have a turbo setup running on the stock engine in the car. I am going to drop this built block in then I am done.
I would suggest a heavier stockish FW for boost. LSD clutch with close to stock feel. Good choice on cam; valves not needed, but springs & retainers are definitely something to consider. 750s will be perfect. Throw in an OBX LSD and new bearings/seals where needed.
Good luck!
1 - 2 of 2 Posts
