1 - 4 of 4 Posts
I'm installing an alternator on a D16y8. I have the alternator mounted in the pivot bracket on the bottom, but I don't know what it mounts to on the top. There's a threaded hole in the top of the alternator which looks like it should mount to the block. I've searched through all my parts, and I can't seem to find a bracket that will fit... Can somebody help me out here? Any pictures would help. Thanks in advance.
i save your ass when you wreck
94 hatchback cx
there should be a bracket that bolts to the block that has a long slit in it so u can adj. tension on the alt belt..
1 - 4 of 4 Posts
